mercury 25hp 4 stroke water tube clogged
telfordsam
I have a 2011 25hp mercury 4stroke that i have replaced water pump and thermostat, thoroughly checked all water lines and still cant get water up thru copper water tube to block. I can blow thru all hoses and block clearly. Any help will be greatly appreciated.
alldodge
Remove the lower and place in bucket of water.
Can the shaft be rotated and have water come up the tube?
Faztbullet
Unless you block off the intake under the cavation plate, it wont pick up on a hose. Will work fine in a bucket...
QBhoy
As long as you have the intakes submerged or can verify it’s definitely getting a good supply…and you’re then not getting water up it…that assumed, one might think that it may be clogged with salt deposits further up or it’s not together right and drawing air somewhere.
If it’s salt deposits…I just recently managed to clear out an old Yamaha with the same issue. Believe it or not, I took the lower unit off and turned the thing upside down almost…then poured vinegar into it to soak…after a wee while…I then got a small plastic syringe that came with kids medicine or something…and injected some more vinegar into the tell tale outlet. Did that a few times and eventually it cleared it all out.
