Mercury 25
seaneen
Hi <br />I have a 25hp mercury(2ooo) it starts fine cold but after running it for even a short while it has trouble restarting. turns over fine , plenty spark.<br />also sometimes when engine is running and I put in gear it cuts out, choke sometimes helps but not allways.<br />Any suggestions, I replaced the fuel harness.<br />I live in Woburn MA ANY ONE KNOW A GOOD REPAIR SHOP.<br /><br />I APPRICIATE ANY HELP<br /><br />Sean
andy6374
Re: Mercury 25
Test the fuel pump. If ok, try a carb cleaning.<br /><br />Are you sure you are getting spark on all cylinders?
seaneen
Re: Mercury 25
yes getting spark on both cylinders.<br />Whats a good way to test fuel pump?.<br /><br />Thanks Andy
andy6374
Re: Mercury 25
To test pump: Have someone pump the primer bulb while shifting into gear, if this stops the engine from stalling then it's the fuel pump.<br /><br />More than likely you need to do a carb cleaning
seaneen
Re: Mercury 25
Thanks Andy, I have a feeling you may be right<br /><br />Sean
