Mercury 25 hp float setting
Gkm70526
I have a mercury 25 hp not sure of the year. I looked up the serial number and it say a 92 but the carb has the square plastic bowl on the bottom. My question is what should the float level be set at and also the needle valve is obsolete but i was told that another motor has the same needle valve he thinks it is a 84 yamaha. Can someone tell me what level my float should be set at and also the replacement needle valve. I dont want to buy the manual because I will sell this motor as soon as it is running. Thanks in advance.
Gkm70526
Re: Mercury 25 hp float setting
Serial number is OD116772
carholme
That s/n comes up as:
MERCURY - ( 25 H.P. (1992 ))
Serial No: 0D116772 Model No: 1025201MD
Parts and Service Bulletin list for s/n 0D116772:
Search Results - Crowley Marine
By looking at the two carburetor sections in the parts list, can you tell me which carb yours has the one with the primer injector system or the one without?
Gerry
carholme
Iboats won't let you post that link. Can't you use the parts list I gave you?
Gerry
Gkm70526
The reason I tried to send that link is the parts list you gave me neither of them matched my carb.
Gkm70526
the carb I have is listed as 6416713 thru 6443972 merc 25 if that helps
Gkm70526
I dont really know anything about the history of the motor. I bought it for $100 price was too good to pass up
it runs just the carb needs to be rebuilt I ordered a carb kit but needle valve is discontinued.
Gkm70526
the disc has the numbers 6348337.
