Mercury 25 hp 2 stroke 1997
paceautom
There is a piece of stainless wire attached to choke assembly but it is not attached to anything at the other end, where should it attach? I think it is called the idler wire
I believe it goes through a slot in the magneto plate and is turned 90 degrees.----Then put on the choke assembly.------Advances ignition to control idle speed.
