Mercury 225 EFI v6 2003
Smalbear
Hei. Pleas Help.
I Cant get my motor to push power. it runs good in nutrual an when i put it in gear. But when i put som power on in ger it wont push power like it don`t gets enough Gass. its not water in the gass. And the pressur whit gass to the motor is god. i think ther my be somting after it comes in to the motor.
Pleas help.
Faztbullet
Re: Mercury 225 EFI v6 2003
More information needed: Have you checked compression? Have you check ignition? Is a salt water engine? Is it overcharging?What is fuel pressure reading? Have you tested shift switch? And last do you have a manual???
Smalbear
The compression is good. ignition is good. it is a salt water.
Are going to chek the fuel pressure to day and see if it is good.
I have order the manual. And are wating for it.
are wondering if maybe the fuel pumps are just workin some. det don`t suck enough.
Faztbullet
Check all your grounds to modules and mounting plates with a meter,if all ok disconnect shift switch as some models it kills one side when shifted..
