Mercury 20hp idling /low rpm issue
chev17
Hey i need some suggestions i got a 1971 i believe mercury 20hp the serial number is 7109596 anyways heres the deal the thing will start up just fine and high rpms sounds great with no misses or stumbles but when brought down to idle it seems to miss/ cut out, it will knock itsself down and almost kill and sometimes it wont come back around and it will die. The carb has been gone through cleaned /blew out with air compresser several times replaced fuel pump dia. gaskets, inlet needle idling tube took out and everything cleaned. Tried adjusting the idle screw it seems to be non responsive until either backed way out or screwed way in. The primer ball stays hard. Another werid thing is i dissconect one spark plug and it starts right up and idles normal without any stumbles or backfires on one cylinder and just runs good and sounds good, it doesnt matter which cylinder i run it on it runs good it seems on only one is that normal i wouldnt think so but? Also got good spark and good compression cylinders within 5 of eachother. Thats about all the things i can think of that ive done so far any comments or suggestions will be appreciated
Bankx22
Re: Mercury 20hp idling /low rpm issue
I think you did the same thing I did. Try switching your plug wires! It didnt make any sense to me either the shorter plug wire went to the furthest plug. Maybe that will help, good luck
chev17
I tried it but it wasnt it thanks though.
I started it up tonight same thing it will just like run out of gas when running it seems, i have a clear gas line on it so i can see the gas when its running and everytime it bucks and knocks down an air bubble comes from the carb into the line not sure if thats normal or not also doggy and throttle response with it neutral or forward.
