Mercury 200XL FS DTS vs. Yamaha F200XB?
hostage
I am looking at getting a HD2 OB Four Winns. It has a couple engine options. It seems like it is a challenge to find good comparisons or benchmarks on these engines, other than there specs.
Mercury 200XL FS
200HP 3.4L V6
475lbs
24valves
EFI
87 Octane
Yamaha F200XB
200HP 2.8L I-4
489lbs
16valves
EFI
89 Octane
I am guessing the Yamaha has bigger cylinders. I would most likely put a 4 blade prop on this. I care more about hole shot than top end speed. Reliability and ease of maintenance is very important to me.
dingbat
Mercury 200XL FS
200HP 3.4L V6
475lbs
24valves
EFI
87 Octane
Yamaha F200XB
200HP 2.8L I-4
489lbs
16valves
EFI
89 Octane
I’m a big Yamaha fan but your comparing a V6 to a V4.
If you want “grunt” you want a V6
A fair comparison would be the V6 Merc vs. a Yamaha F200-V6
hostage
I am looking purely what is avaliable for this boat. The only other options is less HP.
dingbat
Guessing Four winns is a Brunswick affiliated company
Why else would offer V6 performance of one brand and 4 cylinder of the other?
hostage
Granted they are both 200HP, but I don't see any torque numbers.
Maybe price was a reason. The mecury was a little cheaper? Brunswick owned boat companies don't appear to sell comepitor's engines.
dingbat
Don’t see torque figures because you can create torque with LU gearing and prop selection.
HP = work over time
Ultimately it’s shaft speed that determines performance.
It appears both have the same LU ratio so performance would be the similar. If anything one would run a little higher rpm to have same performance.
Why do you think you need a 4 blade on an 200 hp outboard?
I’m guessing. The V6 are geared towards the offshore and bass boat crowd
