I have a 1999 200hp EFI Saltwater series Mercury outboard. The electric fuel pump starts running when the ignition key is first turned on but will not quit when, I assume, the correct fuel pressure is attained. The motor will start but will try to flood out. Is the pump controlled by fuel pressure? If so, is there a sensing switch? Is this replaceable or is it contained in the fuel pump assembly?
Thanks for your help in advance.
