I bought the boat about a week ago. I have taken it out about 4 time. Never had a problem. Yesturday every thing changed, long story just to see if anything has to do with the problem. Before returning to the marina about 30 minutes before we went over a sand isle, where we stop and had to push boat out. After the motor had no issue. When we enter the No wake zone on idle speed, engine stopped. NEVER again turn on, I notice that fuel gauge went crazy on retard. The starter turn but NO sparks. Replace fuel filter and drained. Check safty switch. Remove and re-install fuel gauge and started to work fine. I check all fuse, ignition switch gives a short beep and I can hear the fuel pump go on when I turn the switch. I dont know if could be water in the system, if this motor has a water sensor..
Can some one help!!!
