I recently bought a 1979 Baja 15SS with a 1978 175 Mercury Black Max attached. It had not run for 4 years, sat in a barn.
I replaced the water pump, rebuilt the fuel pump, re did all the carbs (two floats could probably use replacing but havent found parts yet), checked all spark, all cylinders 120-125 psi on compression test, and replaced shift cables.
I have tried a 17", 21", 23", and high five 25" pitch prop on this boat last weekend. All of them preformed pretty similar supprisingly on the low end. I chose the 21" three blade SS prop because it ran at about 6k RPM's WOT, so it is about perfect (this motor should run 5800 RPM's WOT)
My problem is the motor is a dog out of the hole. It struggles to get the boat out of the water. Once it gets up on plane it takes off and is fine. When you open the throttle up from a stop, the engine acts like it just boggs down and doesn't have the horse power there. After about 10 seconds it will struggle and get it up on plane then it takes off like normal. If you put it in nuteral, it has no problems reving up like normal.
What is going on here?
I had a Johnson 115 that would yank the boat up on plane and pull a skier, so i don't understand what the issue is with this 175 HP motor.
