Mercury 1500 150hp strait 6 bought half built, help please!
colinmcday
Re: Mercury 1500 150hp strait 6 bought half built, help please!
oh yeah and if you know where this goes or have a photo that would help too cheers
the third and fourth picture you posted go together. the banana looking thing connects to the both the bracket and the gear shifter in the fourth picture. I have mine together with the gear shift cables. I'll take a picture maybe tomorrow and post it for you.
Chris1956
Honorary Supreme Mariner
You appear to have some mixed parts on that motor. There were different fuel pump set up used on different years, and you seem to have both. The lower cowling is from a '76 or '77 motor, but the carbs are not. The '77 motor had a single fuel pump like the one in picture 7, not the dual fuel pump in picture 5 and 6. The item in pic 2 is the shift slide. It should be bolted to the exhaust cover about just below the throttle arm. The item in pic 3 is the arm that connects to the upper shift shaft in the center of the exhaust extension, and runs to the shift slider.
You need to find someone with a similar motor and put them side by side to work it out. I will guess you have a motor from 1973 or so. A part number fromt he block would be helpful. The transom bracket may have a serial number as well.
colinmcday
Yeah the guy I got the boat off had the original engine stripped and the new block half complete so I guess he bought the wrong replacement block for the casings.
does that mean the pump attached to the casing isn't needed anymore? Can I just run a line from the tank to the pumps on the block?
I got the number I'll check it out now.
pompeylads
relating to the 2nd pic , you said that the gear selector bracket was broke ? well on my old 1989 75hp , i broke the same and its karst ally and very hard to get fixed , i ended up buying 1 from ebay and had to get it shipped to the uk , costing just under ?100
