Mercury 150 V6 blackmax idles only with one bank, 3 cylinders
eddy50
I have a Merc 150 v& XR2 from around 1985. Runs well in higher rpms anf full throttle but idles and starts with only 3 cylinders, one side. And I also noticed when it was run without flame arrestor that there is a small hose that comes to the lower edge of flame arrestor frame. When I have higher rpms, everything is fine but when it drops to idle (about 800 rpm) that hose start to spray gasoline. I can use it but would like to get it running as it should. Anu ideas what to do ?
Carbs are WH-29 and just put new needles and they sem to work ok.
Thanks
Esa
Dukedog
have ya got tha manual (oem)? do you know how to test electrics ie: stator, trigger? that "hose" should come from a bib on tha bottom of tha reed plate and plug on to a bib on tha bottom of tha air box...very small amount of fuel there at idle is normal...more like a mist... not a steady "stream".
I am not sure of the year of the service manual I have, but the troubleshooting is pretty common across the years. According to the service manual, you could have a bad idle stabilizer or a bad low speed winding on the stator. You could ohm out the stator leads.
The test for the 40A stator coils are. You may have the older 16A stator:
Blue and red leads should have 3500-4200 ohms
Blue/white and red/white should be the same.
red stator lead and black stator lead should be 90-140 ohms
red/white stator lead and black stator lead should be 90-140 ohms
Swapping stator leads will cause the no spark to move to the other bank of cylinders, if the stator is bad. Also, see if you have a shift interrupt switch. If it sticks, it kills spark to 1/2 the motor.
There are tests for the triggers, however, they would affect spark to pairs of cylinders, not 3 cylinders.
Dukedog
his will be a 16 ..don't remember what ohm readings are for tha it though....no shift deal,,
eddy50
Thanks guys, I will try to check those and I don't have the service manual. And about the fuel spray, yes it is nothing or more like a mist when I have higher rpm but when I drop it to idle (and the only 3 cylinder burn) it is more like a steady stream. I thought that it is because of the crbs feed all the time but when the cyls are not burning the unused gas is flushed out.
Dukedog
fuel spray gets bigger 'cause ya have cylinders that arn't firin' at all....
16 amp stator
Blue
Blue/White
Red
Red/White
Engine GND
Engine GND
Engine GND
Engine GND
5000-7000
5000-7000
90-200
90-200
trigger
Wire (yellow sleeve)Read To (black sleeve)Resistance
Purple wire(#1)
White wire(#3)
Brown wire(#5)
Brown wire(#2)
Purple wire(#4)
White wire(#6)
Purple wire(#1)
White wire(#3)
Brown wire(#5)
800-1400
800-1400
800-1400
