I have a Merc 150 v& XR2 from around 1985. Runs well in higher rpms anf full throttle but idles and starts with only 3 cylinders, one side. And I also noticed when it was run without flame arrestor that there is a small hose that comes to the lower edge of flame arrestor frame. When I have higher rpms, everything is fine but when it drops to idle (about 800 rpm) that hose start to spray gasoline. I can use it but would like to get it running as it should. Anu ideas what to do ?
Carbs are WH-29 and just put new needles and they sem to work ok.
Thanks
Esa
Thanks
Esa
