mercury 150 hp recharging
acez_high
battery does not recharge
? problem with alternator?
battery keeps going dead, new battery
suggestions
jtexas
Re: mercury 150 hp recharging
Assume you've checked the water in your battery? Fully charged battery should measure 12.65 volts (at 80ºF, varies slightly with temp). Hydrometer, $10 at autozone, let's you check each cell to see if one is weak. Wait a few hours after charging to allow "surface charge" to dissipate.
Test of the charging system: measure the battery voltage with the engine running, should be a volt or so higher than battery open circuit voltage at idle...to upwards of 14 at WOT (depending on the motor). Charging system output low, most likely suspect = rectifier...might as well inspect the wiring for corrosion first.
Texasmark
If you have a shorted rectifier diode in the rectifier/regulator module it will do just that. Can't charge as voltage stays as ac. Discharges battery as it is a direct wire to chassis ground.
Mark
steplift20
its your rectifier or regulator, also check the condition of your battery, is it good and the conections
Ace, You might post the year of that motor. There are V6 motors as well as inline six motors that have 150HP. Each has a unique kind of charging system.
