Mercury 150 HP OB died for no reason I know
MMD
Hello. Went out boating and the motor died for no reason I am aware of. Not a gas or battery issue. When trying to start it only clicks. Any possible "easy" fixes??
paddlers
If the clicking is coming from the solenoid it usually means a poor battery connection ! Try a new battery or check your kill switch .
snowbrd84
Put the key in the run position, take a pair of rubber handle insulated pliers or something equivalent so you dont get shocked, and bridge the two posts on the starter solenoid that is next to the starter. If the starter spins, then you solenoid is toast or you could have a bad connection as stated in the previous post... If you are not in the water, or hooked up to muffs, pull the spark plug wires and only do it for a VERY brief second to see if it spins...
