Robin;
What was the condition of the impeller which you removed? Were there any vanes or pieces missing from it? I have looked through your previous posts and nowehere do you mention the year or s/n. Do you have those?
Gerry
Check your intake screens. When you put the lower unit back up, did the tubes line up and the neoprene connector seat and fit tightly ? Sounds like you may have to drop the lower unit and go back over your work. Did the impeller go in ok - could the blades have been bent in the wrong direction, then snapped off - plugging up the works? How about that tiny little key on the shaft that holds the impeller - I've had to hold them in place with a daub of thick grease while I fit the impeller over it ?
Just an FYI, that serial number you posted is for a 175XRI not a 150. Check the powerhead on the starboard side for a core plug with the serial number stamped in it, and see if it says the same thing as the one on the tilt bracket.
Don I checked again and my s/n is OG077334 not OGO77344 it looks like the OGO is OG and a zero not a O.
Found out the problem why the motor was not pissing. I pulled the lower unit off to see what was going on. The mechanic put the impeller in l with the vanes going counter clock wise instead of clock wise. It got hot and melted the impeller to the water pump housing. Not pumping water. I will be giving him a call. I don't wants him touching my motor but he will be giving my money back on the water pump. At least I know the problem now.
