davidraneypt
Thread starter- Joined
- Jul 26, 2012
- 6
I am rebuilding my merc 1400. I pulled the flywheel from the crank shaft and then dissassembled it without paying attention.:facepalm:Now I need to put it back together, but I am worried about screwing up the timing. Does it matter what position the center hub (the dettachable piece mounted in the center of the flywheel) is attached to the flywheel? There is a mark on the flywheel for timing, but I am assuming I now will not be able to use this mark for timing adjustments. This is my first rebuild and would appreciate suggestions/feedback. Thanks
