Thanks for reading this and potentially helping me out...
I bought a used 1996 sugar sands mirage with a 120xr (I think, the flywheel cover is missing, so no serial number). I took it out and I couldn't get it up past 10 or so mph. Idled rough and would not hit high rpm under load. It was idling so rough, I suspected not all plugs were firing. I pulled the 4 plugs, top 2 plugs looked brand new, bottom 2 showed signs of normal use. I tested the plugs by cranking the engine with the plugs removed and found that the top 2 plugs are not firing at all, ever, and the bottom 2 fire everytime.
I know there are some known problems with the electrical box for these mercury models, and I am likely looking at replacing the switchbox, but I was hoping for some advice before doing so.
I did pull the top carb and it is fine, I am getting fuel to all cyls.
BTW, any other place a serial number is recorded besides the flywheel cover?
thanks...
-Steve
thanks...
-Steve
