nateball7777
Thread starter- Joined
- Feb 28, 2004
- 2
I found two post on this issue both seemed to be the triggers but here we go. I got the boat from my grandad he wants me to fix it up it needs alot of work i had to rewire the entire boat. I put a new switch rewired the motor and to no avail the motor turns over but does not fire. I have 12 volts on the red terminal at the switch box i turn the key one time like the ACC postion and get 12 volts on the white terminal i turn the motor over and get nothing on the green terminal this does not seem correct seeing the green terminal is what charges the coil that fires when the triggers say to. From what i have given does it seem the switch box is bad . Thank you for any help you might be able to give.
