mercury 1150 6cyl
JayShae
Hello out there looking for help!!!what year is my motor its a mercury 1150, thunderbolt ignition ser#7097453 with power trim.blue and red stripe.Also what trim oil do I use says to use sae 20 w oil non detergent cant find this oil anywhere.How do I substitute this oil the right way.And last but not least any history behind this motor,I no the water pumps are an issue,and distibutors thanks alot.
carholme
Re: mercury 1150 6cyl
Beginning with 7, that s/n is a Canadian built engine:
115 1977 EL 4567952 - 4855152 7087423
7087423 being the beginning s/n for 1977. As 1978 begins with 7112248, yours is a 1977.
Parts List:
Mercury Parts, MERC 1150
Service Manual P/N: 90-86134--4
90-86134--4 | eBay
In the interim, here is a link to the condensed version of the Clymer manual. Download it soonest to your computer as the link is short lived.
Small Engine Repair Reference Center Home
Gerry
daveswaves
Ensign
You can replace the number 20 oil with transmission fluid. You should disconnect the lines at the trim cyl and flush the pump with tranny fluid. Push the fluid out of the trim cyl by moving the piston up and down. Wrap a rag around the cyl when you move the piston, it can squirt a fair distance:facepalm:.
Chris1956
I had a '77 Merc IL6. I used 5W-30 motor oil in the PTT unit. Never had an issue.
Chris1956
BTW- if you remove all the oil as Dave recommends, you will need to bleed the PTT cylinders. Just add the 5W-30 and forget it.
