Mercury 115 Tacho conundrum...
Superjetjim
I have a 1993 Mercury 115Hp 2+2
My tacho is not working and so far I’ve done the following but still can’t fathom it out:
1) Installed a brand new Merc Tach
2) Set Switch on rear to number ‘4’ as per shop manual
3) Fitted new rectifier box
4) Ran a direct cable (to bypass the grey wire in the loom just in case that was faulty) - went from Tacho gauge signal > grey wire on engine block
5) Tested the voltage at the gauge and it’s power
I can’t think what else it could be, it’s driving me crazy and spent over $200 so far and no fix.
Please help me guys!
Superjetjim
[No message]
Superjetjim
[No message]
Superjetjim
[No message]
roscoe
Do you have voltage from the grey wire at the powerhead, when you put meter between terminal and ground ?
Superjetjim
Thanks Roscoe, I can’t get to the boat until the weekend, but ‘if’ I have no voltage there what do you think the root cause would be of that? Maybe a faulty stator?
Jim
Superjetjim
Further update / request for help please.
I’ve notice if I push the choke in with the key the Tacho jumps into life - as soon as I release the
choke it stops working again - must be something simple surely?
Any ideas guys?
jimmbo
Problem with the key switch/wiring in the control box, perhaps. Get a wiring diagram
Superjetjim
It makes the Tacho twitch for a second when you push the key in (although the Tacho doesn’t read the RPM it just jumps for a second)
