I HAVE A 1998 115 2+2 2 STROKE. Change the water sep filter to a 10 micron. took it out today and take off was slow would not build past 4500 rpm under load and ran only 25 mph used to get 30 to 35. check the plugs top three have oil and gas on them 4th is clean too clean. there is also no idle change when i pull the wire off that plug but is seams to have spark/under idle I can bog it down with wd 40 when i spray it in that carb same with the other three carbs any help? IT looks like it has been running lean for a while could my main be cload I know it is getting some fuel.
