beckoning
- Dec 15, 2010
- 185
I searched for applicable prior posts and found none.
As you can see from the photos, I have a late 1980's (1989?) Mercury 100hp oil injection 4 cylinder. It starts and runs great. At speeds below 2,000 rpm, it runs on 2 cylinders (presumably to save gas?). At speeds above 2,000 rpm, it kicks to 4 cylinders. That all works well. My PROBLEM is the throttle cable seems to have stretched and I cannot figure out how to take up the slack or adjust the cable. Presently, I need to move the throttle stick to 11 o'clock for the rpms to increase above idle speed. A few years back, the engine speed began to increase as soon as I moved the stick forward. In the past, at full throttle (9 o'clock), the motor would reach 6,000 rpm. Now, at full throttle, it will only reach 5,000 rpm....on a good day. The motor runs fine, so I certain it is not a performance problem, but a linkage problem. I think the linkage needs to be adjusted, but I'm unwilling to tear into it without some confidence and knowledge. I only use the boat and motor for fishing on Lake Michigan, so speed is not critical, but it would be nice on a calm day to really move if I want to. If you look at the attached photos, I believe from moving the throttle lever and watching what happens that the lower horizontal lever is the throttle, and the upper horizontal lever is the cam operated lever to kick in the 2 additional cylinders above 2,000 rpm. How to I take the slack up in the throttle mechanism?
Thank you in advance for your assistance.
