mercrusier power steering question
flashback
The strangest thing happened today, I went up to the boat to get it ready for spring and found most of my power steering fluid in the bilge. it appears the power steering resivoir sprung a leak over the winter..Got any ideas? the engine was not turned over(batteries were not on the boat) maybe some water in the resivoir rusted it out.
johnkc
Re: mercrusier power steering question
did you not drain the water out of the power steering cooler when winterized? check there first.sorry, reread your post, have never seen a reservoir spring a leak unless it has been damaged from some thing hitting or rubbing on it .
flashback
Well, went and pulled the pump/resevoir off and found a small hole rusted thru the bottom. cleaned it up, sanded and epoxied the hole. we will see how long it lasts..........thanks all...
