jjones0377
Thread starter- Joined
- Dec 13, 2016
- 35
LOL! Yes. i just scroll straight down to the section i need. Im lazy some days
Turning the prop is going to be a problem since you have to turn it backwards from whatever gear you are in and it will want to turn the water pump impeller backwards. Best to turn the input shaft if you can and make sure you rotate it in the same direction as the motor turns.
Yep...I guess that is what they were suggesting all along.You turn the input shaft and count turns on the input shaft to make ten turns on the prop.
