Mercruser 4.1 Motor will Altenator handle
kscpu
I just purchase a Sun Tracker Party Deck 21 Fish and Ski.
I would like to know if anyone out there would know if the Altenator would handle charging the motor battery and the Trolling motor, while traveling to a location (in the water) to use the trolling motor.
what I would like to do is put a switch (12 relay) on the between the two batteries and while the motor is running, have the two batteries connected and when the motor is not running, the switch would be in the disconnected mode between the batteries.
this way keeping the Trolling motor charged when using the motor.
any ideas?;)
verado7
Re: Mercruser 4.1 Motor will Altenator handle
what you need is called a battery isolator - it will charge both batteries and prevent your start battery from discharging - yes it will charge a trolling battery no faster than you car charges its battery .
kscpu
thanks, I didn't know they made such a thing.
