MPII
Thread starter- Joined
- Aug 1, 2010
- 219
Greetings -
First thing First, Engine 4.3 Merc. LX 92, Alpha One, Gen II.
(Also for the Mods - I felt this was a different question which is why I started a new thread)
So, I ended up with a cracked lower unit on the Gen II. Got a quote from local marina in CBUS ohio. They believe only the lower unit was bad, that the upper "appears" to be fine. They want 2700 bucks to put a reman Mercruiser lower unit on.
Here's my fear = I believe that the upper shaft seal may be leaking which is how water got into the lower unit to begin with and may have caused freeze damage. They said they can't replace that seal without tearing down the upper unit and want another 900 for that. So, if they just replace the lower unit, I'll end up in the same position, i.e., getting water in the lower drive unit.
I was thinking, for the money, buying an SEII unit, Upper AND Lower for 1400 and calling it a day.
Is it true the upper seal cannot be replaced without tearing out the gears in the upper unit?
Can water leak through that seal and allow moisture to get into the lower unit?
Has anyone got any experience with the SEII drives?
