Mercruiser torque settings
montyk1
Not having much luck, rebuild my mercruiser 3.0L today with new exhaust maifold and there appears to be water getting into the oil. What are the correct torque settings for the cylinder head.
Re: Mercruiser torque settings
90/95 ft.lbs.....
Don S
Not sure how it's possible to rebuild an engine without a manual to check specs on all the parts.<br />Sounds more like a "take it apart and put it back together and hope for the best" than an actual rebuild. Was the head and block within flatness specs? Will you be using the proper torque sequence? When do you do the retorque? And what year is it?
