erikgreen
Thread starter- Joined
- Jan 8, 2007
- 3,105
Hey, all;
I have an opportunity to buy a complete Volvo Penta AQ270DP drive system to replace my Mercruiser Pre-Alpha drive/transom system, and I need to know what would be involved in converting if I went to the VP.
The Mercruiser works ok, although the lower unit is on its last legs even after last year's repairs. This VP would be cheaper then a new lower unit from SEI for the Mercruiser. Unless it needs repairs I'd just have to buy a set of DP props (expensive, yes).
The VP comes with "everything but the engine" which I believe is a cracked block. Not sure yet if the guy wants me to haul the whole boat away or what, I'm hoping so.
The drive is from a boat which had a 5.7L engine, so the gearing should be right for my GM 350 - seller says it's 1.95 to 1.
My question is: Is it possible to use this drive system with my 1981 GM 350 engine? I know switching years in the Mercruiser drives is problematic due to bell housing size, etc. I don't know what engines Volvo paired with this drive system. I'm going to ask what engine it was attached to.
What are the gotchas in trying to use this drive with my existing engine? I don't know year or serial on the drive yet, I'll get that when I can. But I'll have to move quick because this is a rather low price for this VP.
Right now reworking the boat itself isn't a problem because I'm doing that anyway, so a new transom hole, engine mounts, etc aren't any extra work.
Thanks,
Erik
Thanks,
Erik
