mercruiser steering problems
rgthompson
I have 1984 wellcraft withouy power steering, the boat pulls hard to the right, the faster the more it pulls,my trim tab is clocked as far to the right as possible. Any advise would be great.
Thank you
NHGuy
Re: mercruiser steering problems
Turn the tab straight back. If it goes right then put the tab to the left. Takes a little experimentation.
Bob_VT
welcome to iboats!!!
Turn the trim tab OPPOSITE of the pull ;)
Fed
You are correct in turning it to the right (in the same direction as the pull) so now trim your motor up a bit and the different attack angle of the prop blades (compare left to right) should neutralise the steering.
