Mercruiser shifting problem
fuelman1
I have a 1981 mercruiser 5.7 260 hp with alpha 1 outdrive. This unit shifts smoothly when engine is off and when first started. After it warms up it is difficult to change gears. It acts as though it is binding up. You can get it out of gear but you really have to fight it and many times you end up going past nuetral and into the next gear. The kill switch does work. I tested it and the engine does shut off. It has been suggested that there is a problem in the lower unit and that when the gears heat up they are not meshing properly. Any thoughts/suggestions?
Re: Mercruiser shifting problem
Ayuh,.....
How long has it been since the Lower Shift Cable has been Replaced,..??
fuelman1
I have no idea when that cable was replaced. I thought about cables but what puzzles me is why it wouldn't act the same when it is cold.
