MerCruiser?s little black box
f_inscreenname
I?m having a issue and I think it may be related to the Thunderbolt IV box.
Some times, for no reason the motor will step up the idle 400rpm?s. Take it for a ride, run it out a little, cruise for a while, come to a stop and it will idle like the choke is on or something. I have checked it when it does this and the choke is not on at all, the carb step up?s are where they should be and the linkage is also where it should be. And then just like that it will drop off and the idle is normal again with no changes.
achris
More fish than mountain goat
Re: MerCruiser?s little black box
Is the ignition module mounted on the distributor? if so, is there a ground wire between the dissy and the engine block? Usually in the harness. If not, then if there is a slight resistance between the dissy and the engine block, then the module will see that and create a new ground reference... and change the timing...
Took me months to find it on the old V6... I believe Merc issued a bulletin about it.. sometime in 95. (After I told them what I found on mine)
When it does it again, have a look at the timing :D:D
Chris..........
JustJason
when the modules go bad the timing usually jumps around.
run it untill it acts up.
when it does, pull your hatch and hook up your timing light.
it may be eaiser to disconnect the throttle linkage off the carb.
aim the light and shoot the timing. do it at idle, off idle, higher rpm (in neutral with the boat in the water). Hold your timing light steady. The mark on the balancer will change with rpm, but at a constant rpm it should hold steady. If your at a constant 2500 rpm and you see that mark bouncing all over the place then the module is most likely bad.
John_S
If it is only when returning to idle, I have had that when switching in/out carbs but forgetting to hook up the return spring. A very slight tap on the throttle shaft dropped the rpms down.
Another thought, is distributer shaft end play. You will get varance when the distributer gears walks up the cam gear, and won't drop right down when you return to idle.
f_inscreenname
AC
There is nothing on the distributor. Just two wires that go to the black box.
I will look for loose wires but I have had this issue (but much less) before and it has been taken apart and put back together again a coupe times. Up until the last couple trips out the symptoms would happen but they were few and far between and always when it was cold. And again it was not the chokes action. When it was 90* in the middle of summer my choke doesn?t even come on. Also an Edelbrock electric choke does not just turn off with out something being moved. So it would be, cold start, motor jumps to 1200/1300 rpm?s, and without me touching a thing it would drop down to 800rpm?s after half a minute and half the time it would stall due to me not being able to move the throttle fast enough. Like when you have to goose it a little keeping a cold motor running. I have the motor a little hopped up so after sitting a couple weeks I expect to have to give it a little throttle assistance on first start. But if you aint ready when it drops it will stall. It happens that fast.
CJ
I have a timing advance light and have checked it before. Everything seems to work fine. Nice steady pace right through the ban. As for checking it when it happened ?..I will try but like I said, it happens and only lasts about 30 seconds and there is not much of a pattern to figure out when it?s going to happen again. If I can get the light hooked up fast enough ??
IJS
Thought it was the carb at first. Been over it with a fine tooth comb. It?s right. I even got a chance yesterday after a run to drop the idle screw back to 800rpm?s when it did it. I step away from the motor and just like that it drops off to almost stalling rpm?s. Again after the initial screw setting I didn?t touch anything for a good 10 seconds.
I had the distributor out this spring and was like new (no slop). I?m sure I will check it again.
achris
....and always when it was cold. ...
This is classic for a bad ground between the dissy and the engine block... Because the dissy and the block are made of different metals (ali/cast iron) they expand at different rates as the engine warms up. If there is no ground wire between the dissy and the block, then there is a small chance that there is a change in the electrical contact between them. It only needs a few milliohms variation for the timing signal to be altered... Different timing = different engine speed.
Just run a ground wire between the dissy and the engine block... If I'm wrong (not unusual) all you will have done is eliminate one possible cause.. and have the knowledge that I talk out of my ***... :D:D:D
I had this happen on the original V6 I put in the boat in 1994. Took me 7 months to find it!!! The dealer and the state Merc rep both gave up after 2!
Chris.........
