mercruiser outdrive will not come off
mercruiser outdrive will not come off. i took the six bolts out, took off the trim arms, put it in foward gear and it wont pull of. need help
Re: mercruiser outdrive will not come off
Ayuh,.... Pull Harder,.....;)
You can try puttin' the rams back on,+ use 'em to help Push....
You can pick up the drive, place a block of 2xwood up under the gimbel,+ SLAM it down a few times,....
If the shaft is Really Rusted/ Frozen into the gimbel bearing,...
It's not unheard of to pull the motor,+ Beat it out with a BFH....
At that point, to Me,...
It's time to find a new/ used transom assembley in Better shape that that 1....
Good Luck,+ Welcome Aboard,.....:)
