just to put in perspective...
the 385 ci small block in my little boat: competition ported afr195 heads with 2.05 intake and 1.625 exhaust valves, comp hydrajulic cam with 226/236 duration, comp cams roller rockers, hardened one piece pushrods, dished forged blower pistons, H beam rods, steel crank, bluprinted and balanced, zero-decked and set up with a .040 quench, edelbrock airgap RPM intake, holley 750 double pumper with a proform body and Quickfuel base, 7 quart oil pan, stock oil pump, stock fuel pump, IMCO powerflow exhaust manifolds with long risers, oversized oil cooler from a big block set up with a 190 degree thermostat, running remote wix filters, Stock thunderbolt ignition with a v6 module, 14 degrees advance all in by 2500 rpms, 30-32 degrees total timing, free flowing gaffrig flam arrestor.
We didn't dyno the current configuration, but is pretty safely around 450 peak horsepower with a fairly flat torque curve. I gaurantee if you drove it you wouldn't think that the free flowing heads, intake and carb (that carb is really flowing a good bit more than 750 cfm, it really just has holley metering blocks and float bowls on it), free flowing exhaust, etc... limits the torque. I can have 4 people in the boat and pull anyone out of the water on a slalom ski with half throttle... with more throttle and the drive trimmed out just a little bit, it'll about stand up on end
I've run several drives and gear ratios and switch back and forth depending on what I'm using it for: an allpha one ss drive or a stock alpha drive. I run redline shockproof heavy gear lube and no drive shower and am not afraid to run flat out with either drive. I make sure NOT to shift into gear above 600 rpms (for alpha drive, can chip a gear and creat a weak spot to have the gearbox come unglued when running hard), and I am careful not to catch air with the hammer down. other than that I run it hard - why spend the considerable time and expense if you're not going to put what you build to use... ;-)
I've held it at 5500 rpms for a half hour or more and routinely run at 400- 4500, even 5000 rpms for miles and miles on end... it's also seen 6000 rpms more than a few times. not a bobble... (knock on wood)
the point? build what you want, search on here and oher places, pay attention to what components you use and it's very possible to wimd up with something that has good manners, will hold together and has some serious pucker factor when you put the hammer down. btw. the posts that 45auto put up on reversion are about the best out there on the web... dead on.
Good Luck with your project! I'll look forward to reading about it!
ps / addition: THE TECHS AT COMP CAMS (AND PROBABLY MOST OTHERS) DON'T KNOW SPIT ABOUT MARINE ENGINE CONSIDERATIONS!
definately not a professional vid, but where we are... ;-)
http://www.youtube.com/watch?v=EHoXsQc6644
