Mercruiser O/D Water Pump Impeller Life?
chiselchst
Thanks for the great responses on the 3.0L life expectancy question!<br /><br />Now I'd like to know if I should really replace the water pump impeller every 2 years? I just picked up a 2002 3.0 A-1, and it might be due...?<br /><br />Thanks in advance!
Don S
Re: Mercruiser O/D Water Pump Impeller Life?
Impellers are an expendable rubber part in your cooling system. It is the only pump that puts cooling water too the engine. While the Alpha I Gen II impellers do last longer and put up with more abuse than the older Alpha impellers, why take the chance. The Gen II should be replace after 3 years. 2 is a little early.<br />During winterizing, the drive "Should" be removed the gear lube drained and changed. At that point its very easy to seperate the upper and lower and replace the impeller.
Haut Medoc
Silt, sand & such will reduce its' life drastically.....If you are a beachin' boater that is something to consider....Don't wait, it is cheap & easy.....If you are not sure of its' condition ....Replace it! & sleep better & boat better!. :) .....JK
chiselchst
That makes sense. I doubt if it's been done (the boat had the original oil filter on it when I bought it 10/10/05).<br /><br />Thanks,<br />Mitch
Haut Medoc
Git 'er done.... ;) ....JK
fseries
im goin on 6 years on the original,,,
Haut Medoc
Fseries, that's great....But when it disintigrates while you are out on the water.....It will be a minute too long ;) .....JK
Originally posted by fseries:<br /> im goin on 6 years on the original,,,
Inexpen$ive Maintance,.......<br />Or,.....<br />Extremely Expen$ive Repair$...............<br /><br />The Choice i$ Your$.............................. ;)
rodbolt
I think Impellers are way overated, run it till it quits and I get new shoes. and a 6 year old impeller will never suffer a "sudden" failure :)
Ayuh,............It's Been Failing for 3 or 4 Years Now,............. Nothing Sudden There......... :D
crazy charlie
You clearly dont believe in preventative maintenance.Make sure you keep up your towing coverage.Charlie :D
