nrasnake
Thread starter- Joined
- Aug 13, 2012
- 62
I started a boat restoration last year on a Conroy X-19 that had sat outdoors (covered) for an estimated 3 years. I am tearing into the sterndrive (Mercruiser MR [1985 improved Alpha I version], SN 6897253) and want to get an idea of what to be looking for and how much disassembly should be done at this time.
Important note #1: When I drained the gear oil last year, it did have some milky appearance, but no noticeable oil/water separation and no metal flakes were found.
Today I got started and my first task was taking out the sea water impeller assembly from the lower unit. I plan to replace the entire assembly. However, I'm a bit concerned with the vertical drive shaft. Visible wear is apparent on the shaft where it rides in the upper housing bearing seal. Of course, looking in the upper housing, I found the bearing seal was torn and half missing. I also noted the bearing seal did not appear to be flush with the gear housing (one side was low) which is probably the reason for the failure.
1. How is the condition of my lower unit vertical drive shaft? Requires replacement, or should be fine?
2. Can I simply pry out the upper housing seal and put a new one in? (technically this seal is "Oil Seal, Lower Drive Shaft Housing" PN 26-96503)
On the lower unit, I engaged forward and reverse and rotated the drive shaft. It felt like the gears were engaging properly, there was little to no backlash, and there were no abnormal noises or skipping. However, I did note lateral play in the drive shaft tapered bearing (just below the impeller assembly) of maybe 1/16".
3. Is play in the tapered roller bearing normal/acceptable?
On the upper unit, the drive shaft looks to be in perfect condition, but the u-joints are a bit rusted on the outside surfaces. However, the gears and joints still operate smoothly.
4. Should I be concerned with the U-joints based on appearance, or can I clean them up, grease them, and be safe to move forward?
5. What else should be inspected/replaced at this point? Should I get into the gears?
Thanks!
Thanks!
