Willaim Pickard
- Jun 15, 2010
- 4
I recently bought a cruiser with a 1994 5.7 L mercruiser with abravo outdrive. Ran well 2 days then the next time I took it out the belt began to squeel when I started it. I stopped the engine--it was turning even though the belt was not moving. Restarted it and no squeel. All seemed well but then overheat the sea water pump was toast. I replaced it and decided that I would change the outdrive oil and grease the driveshaft and check the bellows so I removed the drive. I replaced it and placed rabbit ears on it to test. When I tried to start it there was a loud noise at the back of the engine then it started and the engine ran. I stopped it and tried to restart it. Again loud bumping noise--grinding so I quit. I think that I may have broken something in the starter or gear on crank. Any suggestions from here ?
