Engine is a Mercruiser Mag 350 Ski MPI with 300 hours since new connected to a v drive in a Tige ski boat. Engine is down on power & idles poorly. Installed a new set of plugs and carried out a compression check. Number 2, 3 & 5 cylinders only show 50 psi all the rest are at 170 psi. Squirted some oil in 2,3 & 5 and tried the compression check again. Number 3 & 5 came up to 120 psi, no change on number 2. Stuck rings on number 3 & 5? Valve problem on #2? What to do next? Any of the ring cleaning additives like Mercury powertune or Yamaha ring free work?
