Re: mercruiser gear lube?
My mechanic uses the Merc HP gear lube in my old Cobra drive because he feels it is the best there is, he could just as easily use the OMC/Bomb stuff since he sells their stuff too, it is able to lube the drive even if you have water intrusion, which is the main advantage over a non marine lube.
