- Jul 18, 2011
- 18,888
I have done a few bench test runs of my 1991 Mercruiser 454 (7.4L) after getting all back together from the valve job and general refurbishment. Yesterday, I did a compression test to compare the results from before the valve job.
Here are the 'before & after' results and fancy graph in the image below. Overall, the compression increased by 9 psi on average, and the low compression in cylinders 3,4,5,6 are corrected. (before was 135 psi average, now 144 psi average). I am still concerned about the lower reading I got on the #1 cylinder, it sort of sticks out like a sore thumb among the other cylinders, that are now very consistent.
The columns headings in the chart are from the past 3 tests '2010' (over a year ago), '2011' is before the rebuild, '2012' is after the rebuild. The dashed pink line is from before the valve job, the solid blue line is after the valve job . . .
#1 cylinder was one of the better cylinders when I did a leak test before the tear-down, I am wondering if it is just a valve adjustment issue. I think I will run another test today after an extended warm-up run to see if I get anything different on the readings.
The compression is supposed to be 150 psi according to the manual, but I'll take the 144 psi, considering gauge accuracy, etc. Only 540 hours on the engine, so ring/cylinder wall wear is minimal, based on what I inspected during the rebuild.
Thoughts on the readings in general and the #1 reading of 136 psi?
TIA.
TIA.
