my mercruiser 1989 inboard wont run on cylinders 1 4 6 and 7 whats up with that?
R rchjr Recruit Joined May 12, 2012 Messages 1 May 12, 2012 #1 my mercruiser 1989 inboard wont run on cylinders 1 4 6 and 7 whats up with that?
Josh P Petty Officer 1st Class Joined Aug 26, 2009 Messages 328 May 12, 2012 #2 Re: mercruiser 7.4 need more info
Josh P Petty Officer 1st Class Joined Aug 26, 2009 Messages 328 May 12, 2012 #3 Re: mercruiser 7.4 you should post some maintenance history if any , did it do it last year? did it just start? how old is the fuel? Its odd that is every other cylinder in the firing order... i would suspect an ignition component
achris More fish than mountain goat Joined May 19, 2004 Messages 27,468 May 12, 2012 #4 Re: mercruiser 7.4 Compression test.
L Lyle29464 Lieutenant Joined Mar 10, 2009 Messages 1,261 May 12, 2012 #5 Re: mercruiser 7.4 some of them used an outboard power pack. I would start there.
