Hello,
First, not sure if this is TB IV or V ignition. Any easy way to tell?
Second, the engine is a 1996, 5.7L with 2 barrel. Alpha one gen 2
Boat is a 21' used for offshore fishing only.
Only had it a few weeks, compression good and even on all eight cylinders.
Always started hard but ran OK once going.
We changed all filters, fluids, impeller, cleaned carb with spray, new plugs, rotor, cap.
Sometimes will not start when cold or restart when hot. At those times, spark seems OK from coil wire with gap tester. But cannot get spark from plugs. Then spark comes back at plugs and engine starts again, runs rough, then cleans out and runs OK again. Sometimes happens several times in a row. Sometimes runs for entire day OK, then next day, will not start cold. Sometimes runs OK for hours, then will not restart. Never stalled once while running.
Is the choke working off the ignition electronically? I was thinking it may be an issue. If not, what could fail in the ignition, then work again, then fail again, and have no relationship to hot or cold.
Any ideas would be helpful.
Thanks,
PPRussell
Thanks,
PPRussell
