transom assy serial number not the engine serial number.0K142149 is the
That serial #is right under the Mercruiser logo where the transom assembly is bolted to the transom. It’s not the engine. Thankstransom assy serial number not the engine serial number.
The drive ratio should be stamped on the side of the upper housing. You'll also find the drive serial number there. Post that here and we can tell you what the ratio is. It should be 1.5:1 or 1.47:1.
Where to find Mercruier Stern Drive and Engine serial numbers.
Stern Drive serial numbers. (Continue down to the next posts for engine locations) ---------------------------------------------------------------------------------------------- All Mercury Marine serial numbers follow a particular format, be they Engine, Drive or Gimbal housing. Up to about...forums.iboats.com
Chris.....
To detrmine what engine you have, we need the engine serial number.That serial #is right under the Mercruiser logo where the transom assembly is bolted to the transom. It’s not the engine. Thanks
Ayuh,.... Welcome Aboard,..... 2bbl. carb,..?? 4bbl. carb,..?? Efi,..?? Mpi,..??Anyone know the horse power of a ‘97 5.7 V8 Thunderbolt ? OK142149 is the serial #. Also where do I find the gear ratio ? Just purchased a 1997 Bayliner Capri 2052 LS with this engine.
Gonna find the engine serial #. ThanksAyuh,.... Welcome Aboard,..... 2bbl. carb,..?? 4bbl. carb,..?? Efi,..?? Mpi,..??
Sorry, Don’t know.2 Bbl Mercarb or 4 Bbl Weber.
Sorry, Don’t know.
Engine:Engine SN- 0K147527
Transom SN- 0K142149
Drive SN- 0K047735
That is close enough, depending on 2- or 4-barrel carb.There's a search feature. It looks like a magnifying glass. You can type your question there and see if has been asked before. Looks like between 235 and 265 HP depending on the model engine. There are 6.
https://forums.iboats.com/threads/horsepower-rating-1997-mercruiser-5-7l-v-8-alpha-one-drive.522309/
Ayuh,..... Shoot for 4800 rpms,....What is the max rpm’s for this engine ? Gonna try a BM 14.5x19.
