Hello, I want to give an update on my water in oil on my 1998 mercruiser 5.7, GM Vortec V-8 EFI. I originally thought it was riser or risers gaskets causing the problem.
I replaced the riser gaskets, still had the problems. Replaced the risers, exhaust manifolds(26 years old), still had the problem. I noticed the intake manifold was loose, only a few pounds of torque on the front and back bolts and others were a little loose. I Pulled the intake and noticed some compromised areas on the original gasket, not totally conclusive. I was ready to replace the intake gaskets and noticed a drip of rusty sludge coming from between the head and block at the head gasket. Is this possibly a blown head gasket or worse? Should I do both head gaskets? Do I need to check for other cracks like in the head and block? I think this engine has overheated before, cannot remember. See my pictures.
I probably should have done a compression or leak down test from the beginning, but the clues were leading me to less serious solutions.
Thanks for your help.
