Mercruiser 5.7 Brass Knock/Drain Fitting Help Needed
djohnson00
Hi all,
I needed to replace my knock sensor, and in the process the brass Y-fitting for both the sensor and drain plug came loose. The manual states not to disturb this due to a specific torque from the manufacturer. I have searched for far too long looking for the correct torque or installation instructions without luck. Can anyone assist in telling me what the torque specs are for the brass fitting? Should I use any type of thread sealant as well? Thank you in advance!
Starboard side drain/knock sensor Brass Y-fiiting
Bt Doctur
you will find the answer looking at what comes out of the end of a BULL
Use Permatex Aviation sealant
scoflaw
Ensign
It's the sensor that gets torqued to 12 to 16 lbs. Not the brass fitting. No sealer on the sensor threads
