mercruiser 5.0 winter drain plugs
Searaywinter
I have a 1999 Searay Sundeck with a Mercruiser 5.0 I/O and need to know how many winter drain plugs there are. I have pulled two on the starboard side, four on the port side including the cooler and one on the front(bottom of hose elbow. Is seven plugs correct or am I missing one? Please help.
Re: mercruiser 5.0 winter drain plugs
Ayuh,.... Welcome Aboard,... It sounds like ya mighta got 'em all,...
I pull the bottom of the Big hose off the circulatin' water pump too,...
It can hold nearly a quart in the circulatin' pump,...
If not for the tin backin' plate, We'd be changin' them in the spring too,... :rolleyes:
I'm guessin' the starboard plugs were the Block drain, 'n Manifold drain,...
Portside oughta be the opposite Block drain, Manifold drain, P/S cooler, Cool fuel(if ya got it), 'n whatever the elbow drain is ya got,...
Merc has come up with a few different set ups, some work Great, others suck,...
Not sure exactly which 1 you've got, but the description matches 1 in our fleet, 'n it's 1 of the Better,...
Ya poked, 'n prodded all the holes, 'n got good flows, Right,..??
Bt Doctur
might be correct but a serial number off the engine can get you to the correct manual
