Mercruiser 5.0 mpi problems with warm start
alldodge
honzaskopek
I think yes, need to look there. I will be at the weekend on the boat, so I will check it.
Well, for now I will try swap that relays, check corosion on kill switch and check this IAC cable.
Fun Times
I believe the IAC repair harness is Merc part number 84-8M0062026
A good image here of the harness here, http://www.ebay.com/itm/New-Mercury-...9X4Wyi&vxp=mtr
[FONT=&quot]Female, 2 Pin Idle Air Control (IAC) Repair Kit[/FONT]
[FONT=&quot]84-8M0062026[/FONT]
Use when the replacement of the entire harness is not necessary. Includes the IdleAir Control harness 2‑pin female connector and 2 crimp splices
Fits MCM MPI engines with mechanical throttle body
http://cmmarinedistributing.com/inde...productId=7598
honzaskopek
Ok, I buy it. I checked voltage what goes to the IAC and its about 12-14 volts, isnt it too much?
Fun Times
With the sounds of the description of the symptoms happening with this engine, it seems there could possibly be a number of things to consider looking into.
1) As mentioned the idle air control valve getting to hot sometimes damaging the wire harness / connector and in rarer cases melting IAC components or just becoming sticky and out of sequence.
2) ^ In-turn of getting too hot could also create internal ECM " IAC driver diode failure and needs replaced as this is becoming more common nowadays it seems...But bear in mind heat doesn't seem to be the only thing making the IAC driver fail too so anything is possible to damage the ECM... https://whipplesuperchargers.com/ind...&product_id=73
3) The relays are starting to fail internally. Try 2 new ones and keep the old ones onboard.
Also note that the fuel pump relay handles the key on power to signal the ECM and power up the fuel pump system.....The fuel pump relay should have some pink wires going to it + possibly a green wire too. http://boatinfo.no/lib/mercruiser/ma...er36.html#/120
The Main power relay should have mostly red wires running to it. http://boatinfo.no/lib/mercruiser/ma...ser36.html#/92
4) As mentioned corrosion on wires or wire connections could cause this type of issue too. Loose wire or battery connections too so be sure to check/wiggle all power and ground wires/cables while the key is on waiting for the power to restore itself.
5) Keep a feel of the ECM temperature to make sure it's doesn't seem to be getting to hot too...Maybe try lightly tapping on the ECM to see if it seems to help at all when the time seems needed.
6) Make sure the 50 amp circuit breaker is not tripping/popping out.
What year is your boat?
Fun Times
