RabbleRouser
- Jun 12, 2000
- 1
I have a 1992 Mercruiser 305 Alpha One, Gen II installed in a 22 foot Glasstream boat that apparently has a carbueration problem. I mean this thing eats gas varaciously,(i.e. uses 20-25 gallons of gas in a 2-2 1/2 hour cruise time at 3000 rpm). The engine seems to flood during the first start of the day but eventually will start and will continue to start uneventfully the rest of the day and has plenty of power. Is this normal fuel consumption for this type of engine?? Its a V-8 with a 2 barrel Mercarb carbureator installed on it. If its not normal fuel consumption is there anything I can check externally on the carbureator such a the fuel/air mixture adjustment or maybe the choke? If not I'm open for any suggestions including a Carb rebuild. Thanks.
