rob_bloozer
- Aug 31, 2001
- 3
Mercruiser 488 stalls at low RPM after running for half hour, it will then start again if I open the throttle and it will run at high RPM but stalls again when it drops down to 1800 rpm, eventually it won't start at all. If it sits for a day it starts fine and so does the whole process again. I am figuring that it is vapor lock but the engine bay is not that hot, also there is no misfiring or spluttering. I am going to check the vent on the fuel tank. my question is if it's not vapor lock what other things would create this problem?
