Re: mercruiser 470 stalls going into gear when hot
Yes I still Own the Boat But it is in the back yard right now. Its still cold up here in new hampshire. I did find a couple of not tight intake manifold bolts when it was winterized. This spring I plan to pull the intake and check for a hairline crack in manifold and also check for warpage of the intake to head surface, install a new intake gasket, clean all threads and use loctite. In speaking with the previous owner the motor has been run hot (180-200F) before I replaced the rubber impeller.
